/INIBRI/ENER
Block Format Keyword Describes the initial state for a brick
/INIBRI/ENER/unit_ID
brick_ID Eint
Definition
unit_ID Unit identifier.
(Integer, maximum 10 digits)
brick_ID Element identifier.
(Integer)
Eint Internal energy density.
(Real)
[ J m 3 ]
  1. The internal energy is expressed by volume unit.
  2. The initial state for brick may be defined by more than one block.
