/INIBRI/EREF
Block Format Keyword Describes the initial reference state for solid element using global strain formulation.
/INIBRI/EREF/unit_ID | |||||||||
brick_ID | Isolnod | Isolid | Ismstr | Nsrot |
For each node of the solid element (Isolnod lines)
Xc | Yc | Zc |
For each node with rotational degree of freedom (Nsrot
lines)
Rx | Ry | Rz |
Definition
unit_ID | Unit identifier. (Integer, maximum 10 digits) |
brick_ID | Element
identifier. (Integer) |
Isolnod | Number of nodes of solid
element. (Integer) |
Isolid | Solid element
formulation. Corresponding to the solid formulation of the property definition of this element. (Integer) |
Ismstr | Small strain formulation
flag. Corresponding to the small strain formulation of the property definition of this element. (Integer) |
Nsrot | Number of nodes with
rotational degree of freedom. (Integer) |
Xc | X coordinate in the global
coordinate system relative to the last node coordinate of the solid
element. (Real) |
Yc | Y coordinate in the global
element. (Real) |
Zc | Z coordinate in the global
element. (Real) |
Rx | Historic X rotation in the
global coordinate. (Real) |
Ry | Historic Y rotation in the
Rz | Historic Z rotation in the
- The initial state for brick may be defined by more than one block.
- The reference state nodal coordinate must be written in the same order from 1 to Isolnod as it is defined in the solid element card.
- The coordinate of the last node of the solid element is 0, 0, 0. The coordinates of the other nodes of the element are defined relative to this node.
- Nsrot=4 has been used for the case of Itetra4=1, where the rotational dofs are used for fictive middle node kinematic compute.
