/INIBRI/AUX
Block Format Keyword Describes the initial state for a brick.
| /INIBRI/AUX/unit_ID | |||||||||
| brick_ID | Nb_integr | Isolnod | Isolid | nvars | |||||
For each integration point (Nb_integer > 0)
| V1 | V2 | V3 | |||||||
| etc. | Vnvars | ||||||||
Definition
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| brick_ID | Element
identifier. (Integer) |
| Nb_integr | Number of integration
points. Corresponds to the property definition of this element. (Integer) |
| Isolnod | Number of nodes of solid
| Isolid | Solid elements
formulation. Corresponds to the solid element formulation in property definition of this element. (Integer) |
| nvars | Number of auxiliary
internal variables. (Integer) |
| V1 to Vnvars | First to
Nvarsth
auxiliary variable values (3 per line). (Real) |
- If AUX, format line 3 has to be repeated in order to have nvars auxiliary internal variables with 3 values per line.
- The initial state for brick may be defined by more than one block.
