Manage Subsystem Configurations
Group unique subsystems together into subsystem sets and organize both subsystems and subsystem sets into configurations.
The typical model assembly workflow is to set each subsystem up as an include file. Each configuration of subsystems is then managed through a separate header deck referencing the appropriate include files. This is an efficient way of building a model since updates can be performed per subsystem rather than per system model. However, this requires multiple header decks to be updated, strict management of ID ranges for each include, as well as control over the connectivity between includes.
Subsystems support and enhance this workflow since each subsystem can be written out as an include file. Additionally, all subsystems and subsystem configurations are stored in a single .hm file. When a particular subsystem is updated, multiple header decks can be written out from a single file using configurations rather than editing multiple header decks.
Activation of a configuration will keep active the common subsystems, the unique subsystems in that configuration, and deactivate any unique subsystems that are in a different configuration. Take the vehicle crash model, for example. All vehicle subsystems are common, unique subsystems are front impact left-hand side, front impact right-hand side, side pole impact, and rear barrier impact.
Figure 1. Full Model with Subsystem Configurations
Figure 2. Front Crash Configuration Applied
ID management is covered through the ID Manager. Connectivity between subsystems is managed through Subsystem Attachments and Connectors. This ensures that connectivity is maintained to the other subsystems even if one subsystem is worked on independently.
Common Subsystem
If you do not explicitly assign a subsystem to any specific configuration, it is treated as a common subsystem. It will be automatically included in all configurations, without needing to assign it to each configuration individually.
Activation of a configuration keep active the common subsystems, the unique subsystems in that configuration, and deactivate any unique subsystems that are in a different configuration.
Configuration View
To manage and review subsystem configurations, HyperMesh provides two separate views:
  • Subsystem configuration view in the Subsystem Browser.
  • Subsystem configuration table view.
Subsystem Configuration View in the Subsystem Browser
The standard view for creating and managing subsystem configurations. To access it from the Subsystem Browser, select the Subsystem Include View icon, , followed by the Subsystem Configuration View icon, .
Figure 3. Subsystem Configuration View
Subsystem Configuration Table View
The table view provides a clear overview of the included and excluded subsystems within a configuration. This makes creating and managing configurations easier.
To access this view, from the Assembly ribbon, click the Subsystem tool's satellite icon.
Figure 4. Subsystem Browser Tool and Satellite Icon
Applied Configuration
The first row in the table represents the applied configuration. This row indicates which configuration is currently active and which one will be exported.
Icon Legend
The table uses icons to show the relationship between subsystems and configurations:
Option Description
Blue checkmark - Direct connection The subsystem is explicitly included in the configuration.
Empty circle - No connection The subsystem is not linked to a configuration and will be inactive.
Grayed-out checkmark - Indirect connection The subsystem is included indirectly to the configuration because:
  • The configuration references another configuration.
  • The configuration contains a subsystem set.
  • The subsystem is common.
  • The subsystem is an associated connector subsystem.
Figure 5. Subsystem Configuration Table View
