Inspect Midmesh
Use the Midmesh: Inspect tool to view/fix nodes deviating from the middle of the geometry, such as Nodes off middle, Nodes off solid edges, Nodes out of solid, Edges off solid edges, and Element centers off middle. The fix corrects the mesh to the mid by node movement or splitting elements.
From the 2D ribbon, click the tool.
Figure 1. -
On the guide bar, click
to define inspection options and specify the allowable mesh deviation from the mid.
- Select source geometry.
- Click the Midmesh selector, then select the midmesh entities to inspect.
Find the nodes, edges, and elements above the specified threshold that deviate
from the midmesh and create node/element sets for further handling.
Fix midmesh problems in the following ways:
- Click Fix on the guide bar
to fix all the displayed clusters.Note: After clicking Fix, identified element cluster sets are cleared.
- Hover over issues in the modeling window then
left-click to fix them one by one.
The cursor will display a check mark next to it when an issue can be corrected.
Options for Detecting Midmesh Issues
Access the following options by clicking on the
Midmesh: Inspect tool guide bar.
- Nodes off middle
- Finds all node cluster which are deviated from mid
- Nodes off solid edge
- Finds all node cluster which are deviated from solid edge
- Nodes out of solids
- Finds all node cluster which are deviated out of solid. These issues do not have auto-fix and hence they are grouped under unfixable problems.
- Edges off of solid edge
- Finds all edge clusters which are deviated from solid edge.
- Element centers off middle
- Finds all element clusters whose centers are deviated from mid
