Create Rigid Body Mesh
Use the Rigid Body Mesh tool to create a quick mesh to represent the topology of a rigid object.
Rigid bodies are surfaces that are expected to be treated as undeformable in the solution. One example of a rigid body is in metal-forming. When modeling the results of a die pressing down on a metal sheet, it’s important to model the shape of the die because that determines the shape of the metal sheet after being pressed. However, during a forming analysis the stresses and deformations of the die itself are not of interest, only those of the formed metal sheet. Other applications for rigid bodies include the impactors used in vehicle crash simulation.
A mesh that accurately represents the rigid geometry is important for such simulations to allow the solver collision detection routines to work effectively and accurately. Since stress and deformation of the rigid body are not calculated by the solver, the rigid body mesh focuses on accurately modeling the shape of the body rather than on producing a high-quality mesh. To this end, it uses the same faceting and shading routines that are used for drawing the model graphics. The resulting mesh may have high aspect ratio or extremely tapered elements that would not be suitable for solution, but can accurately represent the geometry.
From the Mesh ribbon, click the arrow on the right of
the selected surface mesh tool to view a drop-down list of available mesh
methods. Select Rigid Body Mesh from this list.
Figure 1. - Optional:
On the guide bar, click
to define surface mesh options.
Select surfaces to mesh.
You can also select solids by changing the target on the guide bar selector.
- Enter an average element size in the microdialog.
- Click Mesh on the guide bar or the microdialog.
