bolt (washer 1) BEAM44
Creates CERIG elements for the head and BEAM44 element for the body.
Restriction: Only available in ANSYS.
The head elements project and connect to the nodes of the adjoining shell elements which form the hole and also the second row of nodes which form the washer layer. The connector location can either be on the edge of the hole, center of the hole, midpoint in between the two holes or on the second row of nodes which form the washer layer. Property and material cards for the BEAM44 element are created.
