Stress Linearization
Stress linearization, a widely used procedure in the Oil and Gas and ship-building industries, is used to analyze stresses in a structure, such as a pressure vessel.
The stress across a section is classified into average membrane, linear bending and peak stresses. Paths or Stress classification lines (SCL) are defined at various sections of interest in the model. The number of points that divide this line into equal segments is specified. The calculation is done as follows:
  1. The stress is extracted by interpolation in a local coordinate system at all the points along the line. The local coordinate system is based on the start and end nodes of the path. See additional remarks for details.
  2. From the extracted stress values in step 1, the average membrane stress tensor and bending stress tensors at the start and end nodes are calculated using numerical integration.
    = ith component of membrane stress
    = ith component of extracted stress value
    = ith component of bending stress at the start node
    = ith component of bending stress at the end node
    L = Length of the path line
    x represents the position of a point along the line
  3. Peak stresses and membrane + bending stresses are also calculated at the start and end nodes.
    = ith component of peak stress at the start node
  4. Finally, invariants for the membrane, membrane + bending and peak stresses are calculated.
Calculations can be done on one or more paths at a time. The results can be viewed as a HyperGraph plot or exported to a comma separated values (*.csv) file.
From the Query tools, click the Linearize tool.
Figure 3.
The Extract-Linearize tool is displayed in the tab area and is broken down into three sections, each of which corresponds with the process order of using the tool.
Path definition
Allows you to create and manage the path definitions. Paths can be created by adding lines and picking start and end nodes.
Line properties such as the number of points and color can also be set once the line is defined. A Review option is available to view the line in the modeling window.
The Path table/list lets you specify the paths for which the calculations will be performed at a given loadcase/simulation step. You can add and delete paths from the list. The table/list can be sorted by clicking on the heading of each column. Repeated clicks on the column heading will toggle between ascending and descending order. In addition, keyboard shortcuts and a context menu are available for items within the list.
Note: Multiple paths can be selected in the table/list using the standard CTRL/SHIFT+click functionality.
Tip: You can use the All, None, Reverse buttons to quickly select/deselect paths in the Path table/list.
Calculation
Allows you to choose the result type that will be used for stress linearization calculation. You can pick either the base stress tensor results from the result file or use the displayed contour that is available.
Plot
Allows you to set which stress components from the calculation will be plotted in a separate HyperGraph window. The layout of the plot windows can also be set. In addition, an option is available to export the calculation as a report to a comma separated file (.csv).
  • Stress linearization is supported only on solid elements and the file must contain stress tensor results on these elements.
  • Stress linearization calculations are performed at the simulation step at which the Apply button is clicked. Therefore even if the path was defined in another step, when applied, the line is updated per the location of the start and end nodes at the current step.
  • Calculations cannot be performed if some points are not on the model (outside specified tolerance) or not on solid elements.
    A message dialog will display stating "Unable to calculate values for line(s) 1. At least one point lies outside tolerance or is not on 3D elements” and you will be provided two options: either adjust the tolerance value or redefine the line(s).
    A suggested tolerance of twice the default value will be shown, which you can accept or modify. HyperView will attempt to recalculate with a new tolerance however if it still does not work, the message dialog will pop-up again with a new tolerance value. The process is repeated until a successful tolerance value is found. However, for some lines, the tolerance adjustment may not work, and you should try redefining the line.
  • The stresses are reported in a local coordinate system based on the line definition. The X-axis of the system is along the line direction from N1 to N2. The other two axes are calculated as follows:
    • If the local x-axis is not parallel to global y-axis:
      Zlocal = Xlocal x Yglobal
      Ylocal = Zlocal x Xlocal
    • If the local x-axis is parallel to global y-axis:
      local y-axis (Ylocal) is negative of global-x if local-x is along positive global-y and vice versa.
      Zlocal = Xlocal x Ylocal
  • There is no live link between the HyperGraph plot and the HyperView window from which it is generated.
  • The report for each line is automatically appended to the .csv file.
