Rename a Rake
- From the Create tools, select .
- From the Streamlines panel, right-click on the name of a rake in the Rakes list and select Rename from the context menu.
- Type a new name into the Rename dialog.
Click OK.
The rake is renamed.Tip: You can also right-click on the name of the rake in the Results Browser tree (listed under the Streamlines folder), select Rename, enter a new name in the name text field and press Enter.
