Delete a Rake
- From the Create tools, select .
- From the Streamlines panel, select a rake from the Rakes list.
Delete the rake using one of the following methods.
- Click Delete (located in the lower left corner of the panel).
- Right-click on the name of a rake in the Rakes list and select Delete from the context menu.
The rake is removed from the list and the modeling window.
