Access the Context Menu
- From the Create tools, select .
From the Streamlines panel, right-click anywhere within the Rakes list.
The context menu is displayed.
Click on one of the available options.
Delete Deletes the selected Rake/Streamline pair(s) from the list. Rename Displays the Rename dialog, which allows you to rename the selected Rake. Show Displays the selected Rake/Streamline pair(s) in the modeling window and activates the corresponding check box(s). Hide Hides the selected Rake/Streamline pair(s) in the modeling window and deactivates the corresponding check box(s). Show Manipulator Displays the graphical manipulator in the modeling window for the currently selected rake/streamline. The Streamlines graphical manipulators allow you to modify the location and shape of the rake interactively by scaling, translating, or rotating the line, plane, or area using a manipulator specific to the rake type (Line, Plane, or Area). Area rakes without the Evenly distributed option activated cannot be graphically manipulated.
The graphical manipulator is linked to the entity display, therefore if a streamline rake is not displayed, the display of the graphical manipulator is also turned off. See the Display State of Graphical Manipulators topic for additional details.
Hide Manipulator Hides the graphical manipulator for the currently selected rake/streamline in the modeling window. See the Display State of Graphical Manipulators topic for additional details.
