Add a Note
  1. From the Annotate tools, click the Notes tool.
  2. To attach the note to a specific entity type, use the guide bar drop-down menu to select the entity type (Nodes, Elements, Components, or Systems).
    Note:
    • Select the Auto Create option check box to create the note as soon as an entity or any empty space is clicked.
    • Clear the Auto Create option check box to first select the entity (or entities) and then create note(s) manually by clicking the Create button. See Create Multiple Notes Simultaneously topic for additional information.
  3. Click on the entity where you would like to create a note or click in an empty space to create a free-floating note.
  4. Drag and drop the note that you just created to place it anywhere in the modeling window.
