Change Note Attributes
- Set the entity selector to Notes and select the note(s) using any of the available methods.
                Right-click on the note to be edited.
Figure 1. Note Context Menu
                     - From the context menu, select Edit to open a floating Entity Editor for the selected note(s).
 - Select an attribute from the Entity Editor to change the note settings.
