Selecting Entities Using the Entity List Tree
From the Entity Attributes panel, you can select entities on a model listed in the entity list tree.
- Pick entities directly from the screen.
- Draw a window around some or the entire model and then use your mouse to pick a group of entities inside or outside of the window. Points can be added or deleted to or from a window.
The mouse controls used to pick entities on the screen are dependent on the settings specified on the Mouse tab. For example, you can set MB1 (or the left-mouse button) to select an entity when pressed. Or, you could also set SHIFT-MB1 to add a point to a window when pressed.
Pick Entities from the Screen
Pick the desired entity on the model with your mouse cursor.
The entity is highlighted.
Note: Depending on your mouse control
settings, the mouse button and additional controls set to select, or pick,
an entity from the screen will vary. See Preferences - Options - Mouse for
more information on setting mouse controls.
Deselect Entities from the Screen
With your mouse cursor, pick the entity on the model that you want to
deselect.
The entity is no longer highlighted.
control settings, the mouse button and additional controls set to select, or
pick, an entity from the screen will vary. See Preferences - Options - Mouse
for more information on setting mouse controls.
Draw a Window and Select Entities on a Model
- Create the window by adding window points to the screen with your mouse cursor.
- To change the size and shape of the window, pick a point with your mouse cursor and drag it until the desired shape is achieved.
Click inside the window to select all the interior entities.
The entities are highlighted.
Click outside the window to select all the exterior entities.
To delete a point from a window, pick the point that you want deleted using the
mouse cursor.
The point is removed from the window.Note: Depending on your mouse control settings, the mouse button and additional controls set to create a window and select entities from the screen will vary. See Preferences - Options - Mouse for more information on setting mouse controls.
Add a Point to a Window
With your mouse cursor, pick the area on the screen where you want a point to
be added to the window.
The shape of the window changes as additional points are added.
additional controls set to add a window point will vary. See Preferences -
controls.
Delete a Point from a Window
With your mouse cursor, pick the point that you want deleted.
control settings, the mouse button and additional controls set to delete a
window point will vary. See Preferences - Options - Mouse for more
Increase or Decrease the Size of a Window
controls set to manipulate window points and select an entity from the
Remove a Window from the Screen
With your mouse cursor, click on any part of the window to delete it.
controls set to clear a window from the screen will vary. See Preferences -
