The Set Wizard Path dialog allows you to select directories in which several files
are stored.
Assembly Wizard file
Task Wizard file
MDL standard include file
Wizard library directory
Report log file
From the Assembly ribbon, select Set Wizard
Paths to access the dialog.
Figure 1. Set Wizard Paths Dialog
Select Use values from preferences file to use the default
paths for the files, or use the individual file browsers to select the desired paths
for the files.
