2026
View new features for Altair HyperWorks 2026.
Create, organize, and manage parts and subsystems.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
Analysis Tasks create systems and forces or motions which load or move the suspension or full vehicle. Tasks can be modified and saved for reuse in other models. Many common suspension and vehicle tasks are included as part of the library. You can also create and run tasks.
When you build front or rear vehicle models using the Model Assembly Wizard you can add analyses using the Analysis Task Wizard that include output requests for Suspension Design Factors (SDFs) which are useful for assessing a suspension’s kinematic and compliance characteristics.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
