Heavy Truck MDL Library
The Truck Library is available as a part of the normal Vehicle Tools Extension. Models can be modified interactively in MotionView to support topologies that are not supported in the Truck Library. The Truck Library is open-source, ASCII-based, and can be modified per user needs.
- Front Suspensions
- Solid axle suspension
- Solid axle suspension with trailing arm
- Rear Suspensions
- Single solid axle suspension
- Single solid axle suspension with trailing arm
- Dual solid axle suspension
- Chassis – Ladder
- Cabin – Conventional/Semi-forward
- Cabin Suspension
- Fixed to Chassis
- Rear coil spring with dampers
- Powertrain - Linear Torque map
- Steering linkages – Pitman arm steering
- Front spring – Leaf Springs
- Rear spring
- Inverted leaf
- Bell crank linked leaf springs
- Z leaf spring with air cushion
- Driveline Systems
- Single-axle driveline
- Two-axle driveline
- Rear drive shafts – 1-piece, 2-piece and 3-piece
The models and topology included in the Truck Library are intended to be the beginning of the simulation process. The model built through the Assembly tool has geometry that properly illustrates the suspension of interest, but in some combinations, will not result in a good suspension design. You are responsible for populating the model with the appropriate suspension geometry, spring and shock absorber data, mass and CG location, bushing data, tire data, and other model information that is required to develop an accurate truck model.
