Rear Suspension Systems
Rear Suspension supports the rear wheels with the help of a solid axle. There are three types of rear suspensions in the truck library.
Rear Single Axle Suspension
In the rear single axle suspension, a solid axle connects the rear wheels with the
support of rear springs. The available rear spring in the rear single axle
suspension are listed as follows.
- Leaf Springs
- Rear Single Axle Suspension with Leaf Springs
- The ends of the leaf springs attach directly to the frame, and the shock absorber is attached at the clamp that holds the spring to the axle.
Rear Single Solid Axle Suspension with Trailing Arm
The rear axle suspension system includes trailing arms, an air spring, and a shock
absorber. The shock absorber and the air spring both extend from the trailing arm to
the frame and mount to the trailing arm at a position rearward of the axle. The use
of trailing-arm in the rear wheels allow for a flatter floor and more cargo room
especially in commercial vehicles.
The main body parts included in the rear solid axle suspension (one axle) with
trailing arm is explained:
- Trailing Arm
- Trailing-arm suspension is a design in which one or more arms are connected between the rear axle and the chassis, toward the front of the vehicle. This allows the rear to move up and down.
- Air Springs
- An air spring is also included in the suspension and is located at a load transmitting location between one of the trailing arms and the frame.
- Bracket
- A bracket pivotally mounts one end of the trailing arm to the frame of the vehicle while the other end of the trailing arm is joined to the frame by a shock absorber and an air spring. Bracket has the effect of lowering the center of gravity of the suspension and moving the force resisting any sway as far from the frame as possible.
Rear Dual Axle Suspension
In the rear dual axle solid axle suspension, two solid axle connects a pair of rear
wheels with the support of rear springs. The available rear spring in the rear dual
axle suspension are listed as follows.
- Bell crank linked leaf springs
- Inverted leaf suspension
- Bell Crank Linked Leaf Springs
- In the bell crank linked leaf springs, two sets of leaf springs are used and is mounted to the frame at two points. Bell crank rocker is attached in the rear-rear leaf spring. It is used to convert translational motion of one object into translational motion of another object operating at different angles. It acts as an equalizer when the load is applied.
- Inverted Leaf Suspension
- In this suspension, the leaf springs are inverted than the normal leaf spring suspension. The smallest length leaf springs are attached at the top and the longest stays at the bottom.
