The frame or the chassis is the main structure over which all other systems are
attached or connected. For a heavy truck, the frame consists of a ladder structure
spanning the length of the truck.Figure 1.
The Frame system consists of a Chassis body that is rigid with a Ladder frame
graphics as shown above. The chassis body has two joints (an Inline and a
Perpendicular joint) that hold the vehicle during static simulation in any full
vehicle event.
Cabin
Conventional/Semi-forward Cab
The full truck model comes with a Conventional/Semi-forward cabin system
that contains a rigid cabin body with graphics.Figure 2.
Cabin Suspension
There are two options available to attach the cabin with the frame while assembling
the Full truck model.Figure 3.
Fixed to Chassis – The cabin is fixed to the Chassis body using a fixed
joint.
Rear coil spring with dampers – In this configuration, the cabin is pivoted
by a pair of bushings in the front and latched to the chassis at the rear
using a pair of coil-spring and dampers (shocks).
