Click on the Assemble icon to
display the Assembly Wizard.
Figure 1. Assembly Wizard Dialog
The Assembly Wizard dialog consists of a series of pages where you can make
selections for systems necessary to assemble the model.
Figure 2. Assembly Wizard Dialog System Selections
Click on Next to navigate to the next page until the last page
shows Finish.
Figure 3. Assembly Wizard Dialog Last Panel
Upon finish, the selected systems are imported into an empty MotionView session.
There is also an option to select Attachments before
Finish.
Figure 4. Attachment Wizard Dialog
Note: The Attachment option would be active if there were more
than one choice available for any system. The attachments can also be changed
through the Attachments Wizard (drop-down under the Wizards group) after the model
has been built.
Once the systems are imported, the model can be further edited like any other regular
MotionView model. Upon saving, the wizard choices
are saved to the MDL.
Assemble a Model
From the MotionView Model menu, select
Assembly Wizard.
The Assembly Wizard dialog is displayed.
Move through the dialogs using Next and
Back, selecting the model type, properties, and
attachments.
Click Finish.
The completed model is displayed in the graphic window.
