Remove an Entity from a Model
  1. From the Model Browser, right-click on the entity that you would like to remove.
  2. Select Delete from the context menu.
    A dialog is displayed warning you that dependencies may exist and prompts you to cancel or continue.
  3. Click OK to remove the entity.
    Tip: Click Cancel to cancel the operation.
