Create Deformable Surfaces from FEM
The Create Deformable Surface From FEM macro enables you to quickly create a matrix of explicit markers to be used in defining a deformable surface.
From the Macros menu, click the Create Deformable Surface From
FEM option.
The Deformable Surface from FEM panel is displayed.
Select a body.
- Click the Body collector to activate it and select a body in the modeling window.
- Double-click the Body collector and make your selection in the Model Tree.
- Click the System collector to identify the system or container into which the deformable surface will be created.
- Select an end type from the drop down menu.
Click the file icon to browse and select the FEM file to be used.
The macro will create a marker at each node location.Important: This macro requires that the FEM model file have a constant number of nodes in each row.Note: If the FEM contains a closed surface in any direction, the deformable surface that is created would also be a closed surface.
- Enter a value for the maximum number of marker rows and columns.
- Click Generate Surface.
