Command Sets
The Command Sets panel allows you to edit command sets for the solver-command file. The command sets for a model are order dependent, since they define the contents of the solver command file.
The panel options change depending on the command set type selected.
Figure 1. Command Sets Panel
Note: Command Sets cannot be created through the GUI. Command Sets can be defined by editing the .mdl file. Refer to MDL Command Set Statements for details.
The following tabs are available:
