Forms
Use the Forms tool to edit general data entry forms.
Record-Based Forms
Some forms contain repeated records of information. Record-based forms can contain records that describe load steps or properties that are repeated for a variable number of entities.When the
                list of records in a record-based form is extensive, a scroll bar allows you to
                scroll between records. Click the expansion button,
, to
                enlarge the text box so you can view and edit the records more easily.
Note: Forms
                    are created using MDL. See the MDL Reference topic for information on
                    creating forms.
