Export Data
The Export Data dialog allows you to export your data to an Excel or text file.
- From the Model menu, select Data Summary or Topology Summary.
 - From the Data Summary or Topology Summary dialog, click Export Data.
- From the Save as type drop-down menu, select Excel files or Text files.
 - Under Select Data, select the data types you want to export with your file. Select All to save all entity types or None to clear all selections.
 - If you choose to save your file as a text file, select Wrapped or Unwrapped from the Format Data drop-down menu.
 - Click Export.
 - From the Save As dialog, select a directory to which you want to save your file.
 - Enter a name in the File name text field.
                Click Save.
                The data is exported.
