Add One Entity to a Model
Right-click on the "Entity" folder (for example, Points) in the Model Browser and select Add "Entity" from
the context menu, or right-click on the "Entity" panel button on the
toolbar.
Tip: You can also right-click on a system in the Model Browser and use the context menu to add an "entity" (for example: , , , , ).The Add "Entity" dialog is displayed for the current entity type.
- The parent system name is displayed in the System field.
Enter a label in the Label: field, if you want to use a different label name
than the default.
The label name can be changed at any time.
Enter a variable name in the Variable: field, if you want to use a different
variable name than the default.
The variable name is required and cannot be changed after it is defined.
- Under Type:, select single or pair, if applicable.
- Select a type (if applicable). For example, when adding a Joint, select the joint type.
- Optional: Enter any notes in the Note: text box.
Click OK.
The new entity is added to the model in the current system, and the Add "Entity" dialog is closed.
