| Driver Outputs |
                      - F2
                      - Steering angle output of the Driver
                      - F3
                      - Throttle output of the Driver
                      - F4
                      - Brake output of the Driver
                      - F6
                      - Gear output of the Driver
                      - F7
                      - Clutch V
                      - F8
                      - Unused
                | Driver Inputs (1) |
                      - F2
                      - Vehicle CG (x) wrt Gyro
                      - F3
                      - Vehicle CG (y) wrt Gyro
                      - F4
                      - Yaw angle wrt Gyro
                      - F6
                      - Roll Angle
                      - F7
                      - Pitch Angle
                      - F8
                      - Unused
                | Driver Inputs (2) |
                      - F2
                      - Longitudinal velocity wrt gyro
                      - F3
                      - Lateral velocity wrt gyro
                      - F4
                      - Yaw rate wrt gyro
                      - F6
                      - Roll rate
                      - F7
                      - Pitch rate
                      - F8
                      - Engine Speed (Only in case of manual transmission)
                | Driver Inputs (3) |
                      - F2
                      - Longitudinal acceleration (wrt gyro)
                      - F3
                      - Lateral acceleration (wrt gyro)
                      - F4
                      - Unused
                      - F6
                      - Unused
                      - F7
                      - Unused
                      - F8
                      - Unused
                | Driver Requests - General |
                      - F2
                      - Distance traveled
                      - F3
                      - Unused
                      - F4
                      - Unused
                      - F6
                      - Unused
                      - F7
                      - Unused
                      - F8
                      - Unused
                | Driver Requests – Long Control (Feedforward traction control)  |
                      - F2
                      - Demand Signal (Acceleration/Velocity)
                      - F3
                      - Control Signal (Acceleration/Velocity)
                      - F4
                      - Error (Demand – Control Signal)
                      - F6
                      - Unused
                      - F7
                      - Unused
                      - F8
                      - Unused
                | Driver Requests - Steer Controller (Feedforward steer control)  |
                      - F2
                      - Path x coordinate
                      - F3
                      - Path y coordinate
                      - F4
                      - Distance along centerline
                      - F6
                      - - Laps completed (Cars/Trucks)
                      - - Demand path curvature (Two wheelers)
                      - F7
                      - Path Error
                      - F8
                      - Distance travelled
                | Driver Requests – Long Control Feedback (PID traction control)  |
                      - F2
                      - F3
                      - F4
                      - F6
                      - Error derivative
                      - F7
                      - Error integral
                      - F8
                      - Unused
                | Driver Requests - Steer Control Feedback (Two wheelers Steer
                  control)  |
                      - F2
                      - Demand lean angle
                      - F3
                      - Vehicle lean angle
                      - F4
                      - Error
                      - F6
                      - Error derivative
                      - F7
                      - Error integral
                      - F8
                      - Steer output
