Event Specific Reports
Various plots are reported in different vehicle events. The plots are selected based on metrics that are important for a given event.
After building a full vehicle model and adding events to the model, you can browse their respective .xml file and run the model to view the reports for each event.
The Reports can be accessed from the browser context menu on each event or you can also use the menu item Analysis > View Reports.
The following topics list the plots, page-wise, for each event:
Constant Radius Event
A list of reports and windows available are as follows:
  1. Steering Input and Accelerations
    • Steering Wheel Angle vs. Time
    • Steering Wheel Torque vs. Time
    • Lateral Acceleration vs. Time
    • Longitudinal Acceleration vs. Time
  2. Vehicle Velocities
    • Yaw Rate vs. Time
    • Longitudinal Velocity vs. Time
    • Lateral Velocity vs. Time
  3. Vehicle Slip Angles
    • Front Sideslip Angle vs. Time
    • Rear Sideslip Angle vs. Time
    • CG Sideslip Angle vs. Time
  4. Roll Angle
    • Roll Angle vs. Time
  5. Steer/Suspension Travel
    • Front Steer Angle vs. Time
    • Rear Steer Angle vs. Time
    • Front Suspension Travel-left vs. Time
    • Front Suspension Travel-right vs. Time
    • Rear Suspension Travel-left vs. Time
    • Rear Suspension Travel-right vs. Time
  6. Steering, roll and torque
    • Steering Wheel Angle vs. Lateral Acceleration
    • Steering Wheel Torque vs. Lateral Acceleration
    • Roll Angle vs. Lateral Acceleration
    • Vehicle Path
  7. Vehicle Slip vs. Acceleration
    • Front Axle Sideslip vs. Lateral Acceleration
    • Rear Axle Sideslip vs. Lateral Acceleration
    • CG Sideslip Angle vs. Lateral Acceleration
  8. Steering Wheel Angle vs. Vehicle Sideslip Angle
  9. Tire Lateral Slip
    • Left Front Tire Lateral Slip vs. Time
    • Right Front Tire Lateral Slip vs. Time
    • Left Rear Tire Lateral Slip vs. Time
    • Right Rear Tire Lateral Slip vs. Time
  10. Vertical Tire Forces
    • Left Front Tire Vertical Force vs. Time
    • Right Front Tire Vertical Force vs. Time
    • Left Rear Tire Vertical Force vs. Time
    • Right Rear Tire Vertical Force vs. Time
  11. Lateral Tire Forces
    • Left Front Tire Lateral Force vs. Time
    • Right Front Tire Lateral Force vs. Time
    • Left Rear Tire Lateral Force vs. Time
    • Right Rear Tire Lateral Force vs. Time
  12. Longitudinal Tire Forces
    • Left Front Tire Longitudinal Force vs. Time
    • Right Front Tire Longitudinal Force vs. Time
    • Left Rear Tire Longitudinal Force vs. Time
    • Right Rear Tire Longitudinal Force vs. Time
  13. Wheel Aligning Torques
    • Left Front Tire Aligning Torque vs. Time
    • Right Front Tire Aligning Torque vs. Time
    • Left Rear Tire Aligning Torque vs. Time
    • Right Rear Tire Aligning Torque vs. Time
  14. Vertical Tire Forces vs. Lateral Acceleration
    • Left Front Tire Vertical Force vs. Lateral Acceleration
    • Right Front Tire Vertical Force vs. Lateral Acceleration
    • Left Rear Tire Vertical Force vs. Lateral Acceleration
    • Right Rear Tire Vertical Force vs. Lateral Acceleration
  15. Lateral Load Transfer
    • Front Lateral Load Transfer vs. Lateral Acceleration
    • Rear Lateral Load Transfer vs. Lateral Acceleration
Single Lane Change Event
    • Yaw Rate vs. Time
  4. Roll Angle
  9. Vehicle CG Displacement
    • Vehicle CG Disp(Y) vs. Vehicle CG Disp(X)
Double Lane Change Event
    • Yaw Rate vs. Time
  4. Roll Angle
Swept Sine Event
  1. Swept Sine: SWA, Lateral Acceleration, Yaw Rate, Roll
    • Yaw Rate vs. Time
  2. Frequency Plots, Magnitude and Phase
    • Ay/Steering Wheel Angle Magnitude
    • Ay/Steering Wheel Angle Phase
  3. Frequency Plots, Magnitude and Phase
    • Yaw Rate/Steering Wheel Angle Magnitude
    • Yaw Rate/Steering Wheel Angle Phase
  4. Frequency Plots, Magnitude and Phase
    • Roll/Ay Magnitude
    • Roll/Ay Phase
Straight Line Acceleration Event
  1. Vertical Tire Forces
  3. Tire Longitudinal Slip
    • Left Front Tire Longitudinal Slip vs. Time
    • Right Front Tire Longitudinal Slip vs. Time
    • Left Rear Tire Longitudinal Slip vs. Time
    • Right Rear Tire Longitudinal Slip vs. Time
  4. Vertical Longitudinal Acceleration and Velocity
  5. Suspension Travel
  6. Steering Wheel Angle and Torque
    • Drive Torque vs. Time
  7. Pitch, Front Lift and Rear Squat
    • Pitch vs. Longitudinal Acceleration
    • Front Lift vs. Longitudinal Acceleration
    • Rear Squat vs. Longitudinal Acceleration
  8. Vehicle Tire Forces
    • Left Front Tire Vertical Force vs. Longitudinal Acceleration
    • Right Front Tire Vertical Force vs. Longitudinal Acceleration
    • Left Rear Tire Vertical Force vs. Longitudinal Acceleration
    • Right Rear Tire Vertical Force vs. Longitudinal Acceleration
  9. Axle Loads
    • Front Axle Load vs. Longitudinal Acceleration
    • Rear Axle Load vs. Longitudinal Acceleration
  10. Longitudinal Acceleration
    • Left Load Transfer vs. Longitudinal Acceleration
    • Right Load Transfer vs. Longitudinal Acceleration
Straight Line Braking Event
  4. Vertical Longitudinal Deceleration and Velocity
    • Longitudinal Deceleration vs. Time
  7. Brake Torque
    • Left Front Brake Torque vs. Time
    • Right Front Brake Torque vs. Time
    • Left Rear Brake Torque vs. Time
    • Right Rear Brake Torque vs. Time
  8. Pitch, Front Drive and Rear Lift
    • Pitch vs. Longitudinal Deceleration
    • Front Drive vs. Vehicle Deceleration
    • Rear Lift vs. Vehicle Deceleration
  9. Vehicle Tire Forces
    • Left Front Tire Vertical Force vs. Vehicle Deceleration
    • Right Front Tire Vertical Force vs. Vehicle Deceleration
    • Left Rear Tire Vertical Force vs. Vehicle Deceleration
    • Right Rear Tire Vertical Force vs. Vehicle Deceleration
  10. Axle Loads
    • Front Axle Load vs. Vehicle Deceleration
    • Rear Axle Load vs. Vehicle Deceleration
  11. Longitudinal Load Transfer
    • Left Load Transfer vs. Longitudinal Deceleration
    • Right Load Transfer vs. Longitudinal Deceleration
Sinusoidal Steering Event
    • Yaw Rate vs. Time
    • Vehicle CG Displacement vs. Time
Brake In Turn Event
  2. Axle Loads
    • Front Axle Load vs. Lateral Acceleration
    • Rear Axle Load vs. Lateral Acceleration
  3. Steering Input and Acceleration
  4. Lateral Load Transfer
    • Front Load Transfer vs. Lateral Acceleration
    • Rear Load Transfer vs. Lateral Acceleration
  5. Longitudinal Acceleration vs. Time
  6. Vehicle CG Displacement vs. Time
J Turn Event
  1. Tire Lateral Slip
  2. Vertical Tire Forces
  3. Vertical Tire Forces vs. Lateral Acceleration
  4. Axle Loads
  5. Steering, Roll and Torque
    • Yaw Rate vs. Lateral Acceleration
  6. Sideslip
  7. CG Sideslip Angle
    • Understeer vs. Lateral Acceleration
  8. Lateral Load Transfer
  9. Steering Wheel Angle vs. Time
  10. Vehicle CG Displacement vs. Time
Throttle-off Cornering Event
    • Yaw Rate vs. Time
  3. Vehicle CG Displacement
Swept Steer Event
    • Yaw Rate vs. Time
  4. Roll Angle
    • Vehicle Path
Pulse Steer Event
  1. Yaw Rate and Vehicle CG Displacement
    • Yaw Rate vs. Time
  2. Steering Input
Throttle-off Turn-in Event
  3. Axle Loads
  4. Steering Input and Acceleration
  5. Front Axle Sideslip vs. Lateral Acceleration
  6. Lateral Load Transfer
  7. Engine Torque vs. Time
  8. Vehicle CG Displacement
Step Steer Event
    • Yaw Rate vs. Time
  2. Vehicle Slip Angles
  4. Lateral Tire Forces
  5. Longitudinal Tire Forces
  6. Vertical Tire Forces vs. Lateral Acceleration
  7. Steering Wheel, Torque and Roll
  8. Vehicle Slip vs. Acceleration
  9. Lateral Load Transfer
Power Off in a Straight Line Event
  2. Axle Loads
    • Front Drive vs. Longitudinal Acceleration
    • Rear Lift vs. Longitudinal Acceleration
  3. Steering Wheel Angle vs. Time
n-Post Shaker Event
A list of pages and windows showing results. The report uses the .rep file created while exporting the solver deck (.xml). The .rep file contains information on signals that are plotted.
  1. Signal Type = Acceleration/Displacement
    • Animation of the Event
    • Vehicle Body Accelerations
    • Steering Wheel Accelerations
    • Wheel Restraint Forces (as many pages as the number of wheels)
    • Actuator Displacements (as many pages as the number of actuators)
    • Actuator Forces X/Y/Z (as many pages as the number of actuators)
  2. Signal Type = Force/Moments
    • Actuator Force/Moments
Stability Analysis
  1. Analysis Mode = Linear
    • Eigenvalues reported by MotionSolve for the model (.eig file)
  2. Analysis Mode = Apply Pulse/Apply Disturbance
    • Applied Pulse or Disturbance
      • Force Magnitude
      • Torque Magnitude
      • Steer Angle vs Time
      • FFT Magnitude of Steer Angle
    • Vehicle Displacements
      • Roll Angle vs Time
      • FFT Magnitude of Roll Angle
      • Yaw Angle vs Time
      • FFT Magnitude of Yaw Angle
