Feedback PID Steering Controller - Cars & Trucks
A Proportional-Integral-Derivative (PID) steering controller is a feedback controller that computes a vehicle steering input using the error, the integral of error, and the rate of change of error between the desired vehicle path and the actual vehicle position.
To use a PID control you enter proportional (KP), integral (KI), and derivative (KD) gains, the Demand Path similarly with the Feed-forward steering controller and the type of the controller. The Altair Driver then applies the Proportional-Integral-Derivative (PID) control law to calculate the steering signal.
The controller block for PID steer controller is given
below:
[PID_STEER_CONTROLLER]
TAG = 'PID'
TYPE = 'FOLLOW_PATH'
PATH = 'PREDEFINED'
BLOCK = 'PATH'
KP = 0.2
KD = 1.0
KI = 0.0| [FEEDFORWARD LONGITUDINAL CONTROLLER] | ||
| TAG | Attr - string | REQUIRED <PID> |
| TYPE | Attr - string | REQUIRED <FOLLOW_PATH> |
| I_ACTIVE_BAND | Attr - real | OPTIONAL
If absent:
| KP | Attr - Real | OPTIONAL
If absent:
| KD | Attr - Real | OPTIONAL
If absent:
| KI | Attr - Real | OPTIONAL
If absent:
| INITIAL_ERROR | Attr - Real | OPTIONAL
If absent:
