The Selections sub-section shows the Geometry and Particle Selections. By default,
selections are not available unless you have configured them using Setup Selections.
To display the Selections sub-section:
Configure the following options for each of the Selections:
Select the Properties by Selection Group
checkbox to enable or disable the display and color of the
selection.
Select the Display checkbox to enable or disable
the display of the selection.
For example, if Manual Selection of particles is highlighted, you can
select to display or hide this selection.
For Color by
Selection Group, select the checkbox to color only
the Selection Group using the Coloring settings.
Figure 1. Display Selection On Figure 2. Display Selection Off
For Equipment, select Filled,
Mesh, or Point
style display.
For Particles, select
Default, Cone,
Vector, Stream, or
Template. The following image shows the
selected group of particles displayed by Vector while the remaining
particles are displayed as default:
