You can analyze Meta-Particles to understand certain associated attributes. The
analysis considers a Meta-Particle based on its current state in the simulation. Once a
Meta-Particle breaks, it forms two Meta-Particles. For this analysis, all single particles
are considered Meta-Particles.
You can perform analysis on Meta-Particles based on the following attributes:
Length (bounding box, extent or distance based)
Mass
Number of Particles
Volume
Position
Number of Elements
Bounding Box Method
The Bounding Box method creates a bounding box around the Meta-Particle and then
calculates the diagonal for that box.
Length Extent
The Length Extent-based method adds the length or diameter of each element in the
system, especially for long, continuous Meta-Particles. This method assumes that
sphero-cylinders are bonded end-to-end.
Length Distance-based
The Length-based approach takes the two further-apart particles and calculates the
distance between those two particles.
Known Issues
Selections are not supported for Meta-Particle Analysis.
All elements in the simulation are analyzed, irrespective of whether they
are a part of the Meta-Particle or not.
