Apply a Template to a Plot
Change the plotting parameters while viewing the plotted results by switching to a different template.
You can apply different templates to the plot for the running jobs and completed job result files.
On the Results viewer pane, have your plot result displayed.
The drop down list is displaying the chosen template name for the current plot.
Figure 1. Selected Template Name
Select a suitable template from the Template drop down list
A new plot result is displayed with the new template plotting parameters for the same result file.
Figure 2. Plot Result based on the Template
Tip: Click
to return to the
plot TOC to modify the plot parameters.
