Visualize Plots
You may visualize your results from the Files and Jobs tabs.
                Choose your option:
- From the Files tab, open the Job ID folder to select an output file that you wish to plot.
 - From the Jobs tab, here are the two options to visualize
                        plots:
- Click the Job ID which is in the running state, the Running Folder displays the processing job result files. Select a file that you wish to plot.
 - Open the Job ID folder from the jobs list, select an output file that you wish to plot.
