Save a Plot
You can save the plot you generated with the data as a .rvs file.
In the plot view, click
The Save Plot dialog box is displayed.Figure 1. Save Plot
Enter a Name for your plot.
Note: By default, the selected result file name is saved with .rvs extension in the current job directory.
- Optional:
To modify the location, click
to connect to the remote file browser and
select a new location.
Tip: Click Reset to current directory to select the current job directory. -
Click Save.
If another file exists with the same name, a confirmation message is displayed. Select Yes to overwrite and No to enter a new name.Tip: You can open your saved plot to compare it with another plot using the overlay feature.
