Log into Access Web
Login to Access Web so that you can submit and monitor jobs.
Enter the URL https://<hostname>:4443/pbsworks in the
address bar of a supported browser.
where <hostname> is the IP address or hostname of the machine where Access Web is installed.The Access Web login screen is displayed.Troubleshooting: Contact an Altair Application Engineer if you are unable to access the login screen.
- Enter your username and password.
Click Log In.
Note: A localhost cluster is added by default, if Access Web is installed with PBS Application Services (PAS).
Figure 1. Local Host Cluster
Troubleshooting: If the below message is displayed after logging in, a service
cluster must be added. Only users that have been assigned a Manager role can add
service clusters.Figure 2. No Clusters Available
