App Composer
Access Web provides an easy way to create a user defined application definition (app def) using the App Composer.
The App Composer provides an easy way to:
- Add executable commands
- Add pre and post job execution scripts
- Manage app def parameters
- Test and onboard app defs
You can now create application definitions in Access Web without depending on the site administrator or editing XML files.
The user defined application definitions will be listed in the Jobs tab. They will
also be displayed in the context menu when you right-click on an input file.
- Edit the application definitions
- Publish a local application definition
- Publish and Unpublish a global application definition
- Share an application definition
- View a shared application definition
- Clone an application definition
- Delete an application definition
