Unpublish a Global Application Definition
Remove a published application definition from the global application definition list.
Note: Only administrator can remove the global application definition.
The administrator who has published the application definition can remove the application definition from the global list.
Click
Select App Composer.
The Applications panel lists all the application definitions that is created, shared and published.
Figure 1. App Composer
The
indicates that it is a shared application
definition.The
indicates that it is a published application
definition which is global app def available to all the
users. -
Click
next to the application definition that you want to
unpublish.
Figure 2. Application Definition Option
Select Unpublish in the context menu.
Figure 3. Unpublish Application Definition
A notification is displayed.
Access Web will get a notification that application definition has been updated.
The application list is updated and
is removed.Figure 4. Applications List
