Edit an Application Definition
Edit and save the application definitions.
The Applications panel lists all the application definitions that you have created. You can edit and save the application definitions.
Click
Select App Composer.
Figure 1. App Composer
Click
next to the application definition that you want to
edit.
Note: You can also click on the application definition to edit. -
Select Edit in the context menu.
Figure 2. Edit Application Defintions
The application definition parameters are displayed in the Compose panel. - Update the application definition parameters as per your requirement.
Click Save.
Note: The application definitions that you have created are in JSON format and is stored at /home/$USER/userapps. The System Administrator can configure the path so that you can edit it in the Text Viewer.
