Share an Application Definition
Share the application definition that you have created to your team members.
The Applications panel lists all the application definitions that you have created. You can share a copy of your application definition to your team members.
                Click
                Select App Composer.
Figure 1. App Composer
                Click
 next to the application definition that you want to
                    share.
                Figure 2. Applications List - Options
                Click Share a Copy in the context menu.
Figure 3. Applications - Share
Share Application dialog box is displayed.Figure 4. Share Application
                Enter the user names to share the application definitions.
                Click Share.
                The application definition will be shared and the following notification is displayed.
The application definition list of the user to whom it is shared will get updated.Figure 5. Applications Lists
Note: The user can click
 to view the user who has shared the
                            application definition.
