Delete an Application Definition
Delete unwanted application definition.
The Applications panel lists all the application definitions that you have created. You can delete the unwanted application definitions.
                Click  . .
                Select App Composer.
                The Applications panel lists all the application definitions that you have created.Figure 1. App Composer
                Click  next to the application definition that you want to
                    delete. next to the application definition that you want to
                    delete.
                Click Delete in the context menu.
                Figure 2. Delete Application
 The application definition is removed from the list.
