View a Shared Application Definition
View the shared application definition and save it as a local application definition.
The Applications panel lists all the application definitions that you have created
and the shared application definition. You can check the user who has shared the
application definition by clicking
The application definition must be saved locally to view, edit, clone, share, and publish.
Click
Select App Composer.
The Applications panel lists all the application definitions that you have created and shared by others.
Figure 1. App Composer
Click
to view the user who has shared the application
definition.
Figure 2. View Shared Application Definition
Note: Delete is the only option that will be available till you save the application definition locally.Figure 3. Delete Application
Click the shared application definition to view its parameters in the Compose
panel and to save the application definition to locally.
Figure 4. Applications List
A notification will be displayed.
Click
next to the application definition to view the
complete options of the application definition.
Figure 5. Applications List - Options
