Create a Plot from the Job Running Folder
A plot can be generated from a running job file. As the job progresses you can view the latest plot data of a running job.
Click any of your running jobs from the Jobs tab.
The Running Folder is displayed.
Figure 1. The Running Job Folder
Right-click a plot file and then click .
The plot Table of Contents (TOC) is displayed.
Figure 2. Table of Contents
- Optional: Enter a name for Plot Title.
- Optional: Enter a name for X-Axis Title.
- Optional: Enter a name for Y-Axis Title.
- Optional:
Enter a name for Template Name.
The first time you create a plot, the default values are displayed in the TOC. If you change any parameters, click Generic Template to reset their values.
- Optional:
Click Subcase and select the required load case.
Note: By default, the first entry in the subcase list is considered for a plot.
- Optional:
Click Simulation to select a simulation query.
Figure 3. Plot Simulation Query Menu
- Click OK.
For X-Axis parameters, to choose different parameters click
located to the right of the field.
Note: By default, the first entry in the result parameters list is considered for a plot. -
For Y-Axis, select the required parameters from the Result
Type, Request and
Component sections.
Figure 4. Select Plot Parameters
The selected components are added as X-axis and Y-axis variables.Tip: Click
to clear the Y-axis selections.
- Optional: Click Set Template as Default check box to set this template as a default template. The next time you open result files of the same format, the template will be applied and the plot will be automatically generated.
Click Plot.
The plot is generated and displayed. The images here shows that the running job is being refreshed and displays the latest plot result files.
Figure 5. The Running Job Plot Result File Data
A message about refreshing the result file data is displayed.
The plot is updated with the latest data.
Tip: Click
to return to the TOC to modify the plot
parameters.
