Visualize Animations
You may visualize your completed results from the Files and Jobs tabs.
Choose your option:
- From the Files tab, open the Job ID_timestamp in the files list to select an output file that you wish to animate.
- From the Jobs tab, Open the Job ID folder from the jobs list, select an output file that you wish to animate.
