Set a Default Template
Set a default template to view plot results directly.
Follow the steps to set a default template:
Click
of a template.
Choose one of the options:
- Click Set As Default from the context menu.
Figure 1. Set Plot Template as Default
- Click Set Template as Default check box at the bottom of the plot TOC.
The selected template will be set as a default template.
