SS-V: 1160 Stress Concentration in a Groove Shaft
Test No. VS17 Find the stress concentration in a grooved shaft.
Definition
The shaft is fixed on one end. A bending moment of 98125 N-mm is applied on the other
end. Bending stress is calculated as 1 MPa using the equation below.
Where,
- d/2
- πd4/64
The model parameters are:
- Parameters
- Value
- r
- 25 mm
- D
- 150 mm
- d
- 100 mm
- r/d
- 0.25
- D/d
- 1.5
Results
The following table summarizes the stress results.
| Theory1 | SimSolid | % Difference | |
| Bending Stress [MPa] | 1.5 | 1.4865 | 0.9 |
1 Page 1030 ,
Shigley’s Mechanical Engineering Design, Ninth Edition, Richard G Budynass and J.
Keith Nisbett
