SS-V: 1110 Notched Plate
Test No. VS12 Find Sx stress in the notch and top face of a notched plate.
Definition
The left face is fixed. The load is a moment of 500 lbf-in applied to right face.
The units are IPS.
The model parameters are:
      - Parameters
 - Value
 - Length
 - 16 in
 - Width
 - 5 in
 - Plate thickness (r)
 - 0.5 in
The material properties are:
    - Properties
 - Value
 - Modulus of Elasticity
 - 30e+6
 - Poisson's Ratio
 - 0.3
Results
The following table summarizes the
        stress results.
| Reference Solution | SimSolid | % Difference | |
| SXX Stress in Notch [psi] | 7.3100E+02 | 7.4074E+02 | 1.33% |
| SXX Stress along top face [psi] | 2.4000E+02 | 2.4009E+02 | 0.04% |
1  LM-ST-1 Learning
        Module Static Structural Analysis, Dr. Jack Xin, Dr. Liang-Wu Cai, www.femlearning.org,
        2010
