2026
Solved verification models.
View new features for SimSolid 2026.1.
Discover SimSolid functionality with interactive tutorials.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Create an analysis for your project.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
The purpose and format of the SimSolid verification problems document.
Learn how to access and download required model files.
Test No. VE01Propagation of the fundamental mode wave in a waveguide at different frequencies
Test No. VE02Propagation of the fundamental mode wave in a waveguide and reflection from dielectric boundary
Test No. VE03Propagation of the fundamental mode wave in a loaded waveguide
Test No. VE04Analysis of modes in resonator with two materials
Test No. VE05Modal analysis in resonator filled with conducting material
This section provides quick responses to typical and frequently asked questions regarding
