2026
Solved verification models.
View new features for SimSolid 2026.1.
Discover SimSolid functionality with interactive tutorials.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Create an analysis for your project.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
The purpose and format of the SimSolid verification problems document.
Learn how to access and download required model files.
Test No. VNL01 Find temperature at the material interface and maximum deflection of the beam.
Test No. VNL02Find vertical displacements of a Z-shaped cantilever beam under transverse loads of varying magnitude.
Test No. VNL03 Perform analysis of buckling and post-buckling of a thin-walled frame-like structure in the shape of right angle.
Test No. VNL04 Find reactions at the fixed ends and maximum displacement of a bar axially loaded beyond plasticity.
Test No. VNL05 Find residual deformations in a bar axially loaded beyond plasticity.
Test No. VNL07 Find total or partial beam separation/slippage depending on the applied loads.
Test No. VNL08Find displacements of a hemispherical shell loaded with inward and outward concentrated forces.
Test No. VNL09Find out reactions at the punch pressed on large block for perfectly plastic and isotropic hardening materials.
Test No. VNL10 Find the rotation of cylinder subjected to a moment of 10 N-m along its length.
This section provides quick responses to typical and frequently asked questions regarding
