2026
Solved verification models.
View new features for SimSolid 2026.1.
Discover SimSolid functionality with interactive tutorials.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Create an analysis for your project.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
The purpose and format of the SimSolid verification problems document.
Learn how to access and download required model files.
Test No. VC01Find the deflection, bending and shear stresses in a simply supported laminated strip.
Test No. VC02This NAFEMS composite benchmark involves a long, thick cylinder composed of isotropic material, reinforced with external hoop windings made from orthotropic composite material. The benchmark evaluates the capability to accurately model pressure and thermal loading in laminated composite structures.
This section provides quick responses to typical and frequently asked questions regarding
