2026
Solved verification models.
View new features for SimSolid 2026.1.
Discover SimSolid functionality with interactive tutorials.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Create an analysis for your project.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
The purpose and format of the SimSolid verification problems document.
Learn how to access and download required model files.
Test No. VTL01 Find stresses in a support structure with a rigid beam, steel, and copper bars subjected to load and uniform temperature rise.
Test No. VTL02 Determine the displacements at the centerline at free end and bending stress at outer fiber for a bimetallic cantilever beam.
Test No. VTL03 Determine stresses along a constrained straight bar under uniform temperature.
Test No. VTL04 Determine stresses at the top and bottom of a constrained straight bar under linear temperature field.
This section provides quick responses to typical and frequently asked questions regarding
